Just wanted to know the best way and the best program to use to crop a video. IE: adding black bars to hide bad sections of the video.
Thanx
If you're using TMPGEnc, under settings you can set the parameters for cropping. It also lets you use other colours than black for masking.
I know TMPGEnc works for AVI, MPEG1 & MPEG2 (if your AVI is DivX, make sure proper codec is installed). -
but beware; cropping or clipping will re-encode the previous file so you will lose quality....
"OO"P3-1.4ghz Tualatin/Slot-T adapter/AX6BC/Matrox G-200 Marvel16mo/320Rams-133@100/SBLive oem/DR-CDrw 16X/Raceleader FF wheel/ 2 X WD Caviar 40G 7200 + Fuji 11G 5400 HDS/ Q71/Win98 top notch/DX9/DSL/and faith in a good pc setup...oo -
It would be uselful to start with if you told us what video format you are starting from, which output format you are looking to achieve, and on what operating system?
How to crop a video?
By toqi786 in forum EditingReplies: 22Last Post: 27th Jul 2012, 21:37 -
Crop a Video
By jjis in forum EditingReplies: 3Last Post: 21st Jan 2012, 12:27 -
How to Crop Video
By xiaomanda in forum Newbie / General discussionsReplies: 6Last Post: 14th Jun 2011, 09:24 -
Crop a video?
By Cined in forum EditingReplies: 1Last Post: 29th Apr 2010, 07:50 -
Crop video
By weta in forum Newbie / General discussionsReplies: 10Last Post: 11th Aug 2009, 15:27
