Please, help me!!!
When I open a certain AVI file with VirtualDUB, it gives a error,
"VBR audio stream detected"
"VirtualDUB has detected an improper VBR audio encoding in the source AVI file and will rewrite the audio header with standard CBR values during processing for better compatibility . This may introduce up to 3381ms of skew from de video stream. If this is unacceptable, decompress the *entire* audio stream to an uncompressed WAV file and recompress with a constante bitrate encoder. (Bitrate: 133.6 +- 17,2kbps)."
I don't know what can I do to fix it. I'm just a beginner.
So, can someone help me with it?
Thanks.
Alexandre Ricardo
Powered by Thunderdird
You need to save out the audio uncompressed or save it as it is then uncompress it later.
Try this first
Audio > full processing mode
Audio > conversion > 44.1Khz
SAVE WAV
If that fails you need to save it out as it is and convert it later
Audio > Direct stream copy
SAVE WAV
You may now have a WAV that's an AC3 encoded, so rename it to .AC3 then use headac3 to convert it to a uncompressed WAV http://mitglied.lycos.de/darkav/svcdguide/svcd.html
Now use that WAV and the original AVI in TMPGEnc
Audio has problems in Windows Media Player but not in other audio apps
By brassplyer in forum Software PlayingReplies: 7Last Post: 23rd Sep 2011, 17:12 -
Problems with Audio
By fi3ryfalc0nZ in forum Software PlayingReplies: 3Last Post: 7th Dec 2009, 19:23 -
audio problems
By minigamer in forum Newbie / General discussionsReplies: 1Last Post: 21st Dec 2008, 12:03 -
Audio Problems
By macuser1960 in forum ffmpegX general discussionReplies: 9Last Post: 26th Feb 2008, 15:46 -
Problems w/Audio
By itsmevic in forum AudioReplies: 1Last Post: 9th May 2007, 01:53
