How can I convert a m2v video into a mpeg, avi or any other video format (other than by renaming it) ?
the file extentsion .m2v is usually used to denote an mpeg-2 file with video only (no sound). Just drag and drop into Windows media player and it should play fine. If not, it is not what the file extension says it is!
M2V files work fine, they're music videos. It's just that I want to edit them and neither Windows movie maker, adope premiere, TMPGenc nor virtadub recognize them...
If they play fine, the extension suggests they are mpeg-2 videos. I guess they also contain audio as they are music videos! In Tmpgenc have you tried raising the priority of the directshow filter, that can persuade it to open files it otherwise has trouble with. You could also try changing the extension to .mpg to see if that makes any difference tho I doubt it.
no what he and i want to know is, how do you edit m2v files ?
for example how do you get them to open in premiere?
do you have to convert them to something else ?
is there a program you can use to open them directly?
thanks in advance CGN
Transform .m2v +. wav to full MPEG-2 dvd spec file?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 2Last Post: 14th Oct 2011, 08:13 -
Convert/Mux .m2v and .wav into mpeg for DVD??
By Beavis in forum Video ConversionReplies: 2Last Post: 22nd Jul 2011, 14:46 -
help with ffmpeg args to convert .m4v to .m2v or .mpeg
By rhfritz in forum Video ConversionReplies: 3Last Post: 28th Apr 2011, 12:09 -
Freeware to mux mpeg-2 (m2v mp2) (NOT TMPGEnc)
By 2397to2997 in forum Video ConversionReplies: 12Last Post: 18th Aug 2010, 15:42 -
.m2v to .mpeg sound syc issues
By newsclips in forum Video ConversionReplies: 2Last Post: 5th Jun 2007, 13:36
