Results 1 to 9 of 9
    dave king
    Hi
    i have a pioneer a04.
    If i use spruceup to author will it burn to the disk or will
    i have to use another program like prassi.
    thanks
    dave king
  2. it wont allow you to burn using spruce
    but you can take the vob's and such and use nero or whatever to burn the dvd video itself... i heard nero sucks but it works everytime... i'm actually looking for prassi... is recordnow its successor?
  3. Originally Posted by menaceboy
    i heard nero sucks
    Since when?
  4. I just successfully completed my first oversized DVD........no sync problems......no jerking images. My main problem was my older 1ghz computer couldn't handle Rempeg. It would error at 100%. I am using a 2ghz Pentium with a Pioneer A03 burner. My process was:
    Smartripper >REMPEG >Spruceup. I don't know exactly what it was with the old computer and REMPEG but everything went flawlessly with the Pentium. I used Independence Day for the test due to it's 2.5 hour runtime. Here are the spec differences on the 2 systems:
    OLD: Compaq Presario 7998, 1ghz AMD Athlon, 512mb Ram, Pioneer A03 Burner.
    NEW: Compaq Presario 8000, 2ghz Pentium 4, 768mb Ram, Pioneer A03 Burner.
    I would appreciate some input about the reason the 7998 wouldn't do it.
    May 2001
    Hey, menaceboy,
    Why would something "suck" when it works everytime? That seems like a recipe for success, to me.
    And yes, I believe that RECORDNOW is Prassi's successor.
  6. Originally Posted by SLK001
    Hey, menaceboy,
    i didn't finish my sentence i guess... i heard nero sucks for dvd but its the only thing i use to burn my dvd-r movie backups... so i guess i've been hearing bullshit
    May 2001
    People are saying that NERO "sucks" in posts because later versions will NOT let you burn a non-compliant DVD. All this feature does is help prevent a novice (or an expert) from making DVD-R "coasters". A lot of DVD players "expand" on the actual DVD specs and are tolerant of non-compliant burns - however, players still exist that are NOT tolerant of this type of burn.
    Personally, I appreciate the DVD "check" before I try to burn a DVD-R - it has probably saved me from more than one coaster (and so far, I have had none). I just wish that the error message that popped up would give a little more detail on exactly where the problem is, ie, instead of the dreaded "DVD-Video File Allocation Error", maybe something like "ERROR: Number of Video Title Sets Presented does not match Number in VIDEO_TS.IFO "VMGR_VTSI" Folder" or something like that.
  8. i love that dvd check, it lets me playback my dvd-r's in my ps2, i once bypassed it cause it gave me an error when i trimmed a .vob to a certain filesize with a file cutter.. said something about dvd 2kbyte spec or something... and it worked in my apex set top player but not my ps2,,, nero rulez
  9. spruceup is the king no u cant burn with it on a pioneer but u just create a disk image and burn with prassi easy as. i wouldnt say nero sucks but i dont use for making dvds
    i got a pioneer 103 and dvds r the future specialy copyied 1s lol
