how do u increase the sound, its too low on my dvd player
You should have a volume control on your TV, if you turn that up then.....
So the original AVI/Mpeg has low audio, then you need to use an editor to increase that. www.goldwave.com (With the MP3 plug-ins) is very good, you can maximize the sound, make a mono stereo etc.
Gold wave can load AVI's (Strips audio out) or you can save the WAV from an AVI in Vdub, lots of other methods, also TMPGENC can increase the audio level when your converting from AVI to mpeg1 -
lol -
If your talking about the volume for VCDs and SVCDs...
If you use the program DVD2AVI in your process for making VCDs and SVCDs, then you can select the option NORMALIZATION which really helps adjust the audio before encoding. If you don't use DVD2AVI, then this post is no help whatsoever.
Mojo
Low Sound Output After Adding .ssa to .avi
By edlimym in forum SubtitleReplies: 4Last Post: 12th May 2010, 08:02 -
How to reduce blocky artifacts in low res, low bitrate video
By The111 in forum Newbie / General discussionsReplies: 48Last Post: 20th Mar 2009, 19:29 -
Low sound in rear speakers.
By madman1987 in forum AudioReplies: 5Last Post: 24th Nov 2008, 13:44 -
low sound after burning to dvd
By ymurf in forum Newbie / General discussionsReplies: 3Last Post: 3rd Feb 2008, 15:59 -
LOAD CLICK AND LOW SOUND at join of 2 avi xvid ac3 using vitualdub
By hawklight in forum EditingReplies: 0Last Post: 15th Jul 2007, 09:44
