I would really appreciate if you can help me.
I just burned a film, when i play it on my computer it plays well and the sound is fine, but however, when i play it on my VCD player the sound is really, and i mean really, low.
Can anyone help pls.
You need to process the audio before you convert it to mpeg1. try www.goldwave.com (with MP3 plug-ins) you can load the AVI straight into it, then use maximize etc. then use that WAV with the original AVI to make the mpeg1
TMPGEnc can also increase the volume when your converting Setting > Audio > Use audio edit > Setting
no sound problem
By bountylord in forum Video ConversionReplies: 3Last Post: 26th Apr 2008, 18:37 -
VOB2MPEG sound problem
By rhymejerky in forum Video ConversionReplies: 1Last Post: 26th Apr 2008, 12:06 -
problem with my HP sound
By arabian in forum ComputerReplies: 2Last Post: 27th Dec 2007, 03:51 -
Sound problem on PC
By greenpop in forum ComputerReplies: 2Last Post: 18th Oct 2007, 06:36 -
Problem with sound
By jarko in forum Newbie / General discussionsReplies: 6Last Post: 11th Aug 2007, 20:22
