  1. Guest
    Another problem I have is this error:
    Downmix overflow detected. Restarting Azid with a new gain offset: 5
    CRC error detected in AC3 stream. Processing will continue but you might get sync problems.
    I get this nearly every time and it always keeps trying till the offset is at 1. As it states, I have synch probs. Any Ideas?
    I was using WinMe, but I just did a fresh install of Win2K today and still get the same errors.
    mudflap
  2. Hi Mudflap
    If you use DVD2SVCD you should read some posts in the http://www.doom9.org forum. There is an ongoing diskussion where the author of the software participates.
    Under the tab for Audio you can pre-set the gain to something else then the default 5. I use to have 3 without problem. You maybe have to use 1 as it seems.
    On your synch problem you gave us very little information about the problem. I have no clue.
    I can tell you though, I am finally able to make SVCD's with picture and sound in synch on my standalone Nintaus9901 DVD-player. All thanks to DVD2SVCD and the programs that that shell use.
    Cheers // Radioman
