I just got the new Dell 8200 with cdrom and dvdrom/cdr combo drive so Nero doesn't support my drive for some freakin reason, so I'm left with using the Platinum version of the EasyCD creator with the xp upgrades. Everytime I open a .mpg file to burn, the program Crashes...What is the problem and how can I fix it? I tried using vcdeasy but I also need the drivers for it. My drive is a Samsung cdr/dvd SM 332b. Can someone PLEASE HELP!!!
I have used roxio in the past and had a similar problem everynow and then, if I tried burning an mpeg that never got the big green tick saying that all was ok. If this is the case, try using video impression (NEW -- GET -- PLAY -- and then save as MPEG -VCD PAL blah blah or whatever format you want. Roxia then recognises this file and burns to CD.
tried it...it just gets suck there forever.... HELP!!! Is there any other software out there that I can use to burn VCDs?
Originally Posted by hardbody6pack
or vcdeasy
or, look left at the section called AUTHORwhat are you askin' me for...
I'm an idiot! -
then I got Nero and VCDeasy and daemontools...
no problems nowwhat are you askin' me for...
I'm an idiot!
Roxio Media Creator Suite 10 Stange Results
By DB83 in forum Authoring (DVD)Replies: 7Last Post: 16th Dec 2011, 12:53 -
ROXIO Music Disc Creator 9 --- track Lists / Shuffle
By Trollheart in forum AudioReplies: 2Last Post: 11th Dec 2007, 16:10 -
How do I get Roxio Easy Media Creator to Do What I Used to Do With Nero?
By AlleyCatty in forum Authoring (DVD)Replies: 0Last Post: 20th Nov 2007, 15:27 -
Roxio Launches Easy Media Creator 10
By roxann in forum Latest Video NewsReplies: 0Last Post: 5th Sep 2007, 15:27 -
Problem with Roxio Media Creator 9 and slideshow
By ingeborgdot in forum Authoring (DVD)Replies: 12Last Post: 30th May 2007, 11:58
