  1. okay - i have a divx movie avi file and using TMPGenc I am trying to convert it to a DVD compliant mpg file so that I can burn it using my Pioneer A04. The thing is - after conversion - the video is fine but there is no audio?
    I have set TMPGenc to the all the normal settings and I have used the DVD (NTSC) mcf template as the divx avi is also NTSC.
    Before anyone says anything - yes I know the divx avi is lower quality - so there is no point converting it to a dvd compliant file - but the thing is i want to regardless of quality - all i want to know is where did the audio go?
  2. Strip the audio from the avi using virtualdub. To do this open the avi in virtualdub and:
    Audio-> full processing mode
    Audio->conversion (48Khz) (if reqd)
    Audio->compression (PCM - NONE)
    File-> save wav.
    Use this as the audio input to TmpGenc and encode.
    If this doesn't fix the problem ask again.
    (NOTE: If vdub gives an error when trying to convert, make a note of it and search the forums for the answer)
  3. wow bugster!
    sorry for the delay - was away on holiday. But thanks for that - your method was perfect - and it helped me to sort it out!! Thank you.
