Has anyone successfully used AIW MMC 7.1 to capture an MPEG-2 file that can be used by MSP 6?
My captures using ATI's MMC 7.1 seem to work fine (no dropped frames, looks good in Windows Media Player etc.) but the only capture setting that is able to be used by Ulead Media Studio Pro 6 is VCD. I'm able to capture at much higher quality and my goal is SVCD...
I've found that if I put my captured MPEG-2 file from MMC 7.1 using "Best Quality" (480 x 480, 8 mbps) through TMPGEnc and use the SVCD template, I can then use the file in Ulead MSP6. This means a total of ~8 hours to prepare 1/2 hour SVCD.
The DVD plugin for MSP 6 is nice so I'd like to capture directly from the AIW MMC 7.1 and plop it right into MSP 6 so I can export to the DVD plugin with only one MPG conversion. Any time I try to use any captures other than VCD from the AIW MMC 7.1, the audio stream is not present.
Can I use a different codec in MMC 7.1 to fix this problem? Anyone have any ideas? Thanks.
Results 1 to 9 of 9
I've got an answer to my own question... I emailed Ulead support about this issue several days ago and recently received a reply with a new version of mpeg2.dll attached. I suppose this is a new codec which is more "flexible" and can handle the captures from the ATI AIW MMC 7.1 just fine. If anyone needs a copy for Uleade Media Studio Pro 6.0.0.2 (aka MSP) just reply to this post so I get an email notification... I'll send the dll to you.
Hi msenkbeil. I'm having problems loading my DVDs ans SVCDs files to DVD plugin of Media Studio PRO. (Error in reading frame #) Maybe and only maybe this dll could be my solution. Thanks for the posting.....
Hi msenkbeil,
Could you send me the mentioned dll?
Thanks,
George
(gyorgy.bano@freemail.hu) -
Hi msenkbeil,
please could you send me the new version of mpeg2.dll from Ulead to f.kostal@post.sk ? -
hi, thanks for your post, could you please send the file to jeremypps@yahoo.it and tell me where tu store it? thanks again
Aren't you sorry you offered to send the DLL?
I want it bad,
please send to Angelhito@atlas.cz
Weird Interference ATI AIW Pro
By Tom Saurus in forum ComputerReplies: 8Last Post: 7th Aug 2010, 09:52 -
ATI AIW 7500 64M Replacement?
By TaranScorp in forum Capturing and VCRReplies: 20Last Post: 6th Aug 2009, 11:56 -
rmv Plugin for Ulead VideoStudio
By Metalgod in forum Newbie / General discussionsReplies: 1Last Post: 18th Jun 2008, 22:22 -
ATI Aiw card in Linux?
By Nelson37 in forum LinuxReplies: 9Last Post: 10th Apr 2008, 13:25 -
Where can I find Nero Showtime plugin for ATI Remote Wonder?
By fk in forum Software PlayingReplies: 0Last Post: 13th Jul 2007, 02:53
