help!!!!i'm having a problem converting an avi file to mpeg.i use tmpgenc and 10% into converting my file i get an error message which says INDEX OF SCANLINE IS OUT OF RANGE(240).any help much appreciated
i just opened the file with divfx and ran check errors and got this message
Checking Errors...
NOTE: The error checking is not perfect!
Corrupted data detected at frame 8544
Error offset: 13161642
Corrupted data detected at frame 34899
Error offset: 53084264
Done.
now wot do i do??? -
ive done that but it says there are errors at the same points in the file. wot should i do????
Converting an AVI file in Toast PROBLEM!!!!!!!!!!!
By thasco in forum MacReplies: 10Last Post: 14th Dec 2010, 10:44 -
Converting a AVI file, want to add another video file
By s_joy09 in forum Authoring (DVD)Replies: 7Last Post: 7th Aug 2010, 14:40 -
Audio problem when converting a MPEG file to AVI
By Kareng in forum ffmpegX general discussionReplies: 9Last Post: 18th Jul 2008, 17:50 -
By Kareng in forum AudioReplies: 1Last Post: 2nd Jul 2008, 15:56 -
question about converting flv file to regular avi type of file
By jimdagys in forum Video ConversionReplies: 4Last Post: 28th Nov 2007, 11:39
