  1. Anyone else had this or a similar problem. I downloaded a Divx of the movie a Clockwork Orange (classic) from the Net. When I converted it to MPEG using TMPEGEnc it had a problem with audio synch. I later found that the problem was also in the original Divx. I tried several guides in this forum and posted requests for solutions none of which seemed to work (Even tried dividing the Divx in two parts at the point of bad synch and encoding each to MPEG separately and tried to correct the second half with one of the guides on the forum. In short nothing seemed to work. Then I found what appeared to be a different version on the Net and after downloading it I was delighted to find that the audio synch problem was not there. However after replaying it there was a different audio synch problem about 10 mins from the end (Drats). I can't tell if it is on the original Divx as it does not show the video on Media Player. This is very frustrating as I would like to have a copy of this clasic film on more durable VCD format (I have the VHS so I might have to capture it etc.) Anyone help with this problem!!!
  2. Banned
    Jun 2001
    UK
    You cant see the movie when you play it ?. You need to istall the Nimo codec pack, if you cannot see anything.
    You may also have another codec playing the AVI (Wrong one) this will also be fixed with Nimo.
