  1. Ok, when encoding a video the movie is choppy. Is it supposed to be like that? Its ok during preview. Also are you supposed to get sound during preview? I have done like the newbie guide says to do when converting divx to vcd's.
  2. Banned
    Jun 2001
    UK
    You don't say what your doing at all apart from "Encoding" so at a guess your using TMPGEnc, if so you don't get any sound during preview, and when your viewing the conversion, unless you machine is a super computer, it wont display it in real time
  3. And since you didn't fill out the "computer details" section of your board profile, we have no idea what kind of machine you are running.
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
  4. Sorry about that. Ok..i'm using TMPGEnc. So, that solves that problem. I have filled out the computer details. Now I get to burn it without using VCD easy. Since my burner won't show up. Thanks for the help.
    somewhere close to joisy.
    After encoding just use vcdeasy to create a bin/cue and then burn using something like cdrwin or fireburner.
