i just put this card in my computer and i have no clue on how to hook it up to a VCR to capture shit. If anyone with the same card can help please email me or IM me on AIM at evanskeeee . Thanks in advance for your help.
BTW = P3 1000, 256 megs ram, 30 gig HD 7200 RPM, SB live!value, INtel motherboard,
<font size=-1>[ This Message was edited by: evanskeeee on 2001-07-02 13:25:36 ]</font>
No one wants to help you, but in the spirit of this forum I'll lend a hand. Connect your purple A/V cable to the back of the card. It only goes in one way. Be carefull with the pins, they are tough but still can be bent without care. The connector you want is fartherest away from the monitor connector. Connect the outputs for video and audio from your VCR to the pruple cable. You have another cable which is smaller than the purple one and is black. Connect it to the back of the card on the connector next to the monitor connecor. Take the small micro audio lead and put it into the line-in connector on your audio card so you can hear what you are recording. It the captured video doesn't have sound go to the ATI Multimedia center select TV then select the small box with a check mark. It takes you to options. On the display screen go through initialization. Make sure the audio is set to line-in. Likes to change on its own sometimes. After that is done then selecxt the video tab on the options screen. Select the type of video connection you have. Composite for RCA type connections or S-Video for S-Video type connections. I think that is everything. Are you really having problems setting up or am I misunderstanding the question? If you are having problems setting up I hope this helps, but most of the information is in the 2 blue covered manuals you received when you bought the card. Let me know if I'm off track.
RTFM. (no offense, but the people here aren't a paid tech support line. they don't want to hold your hand through everything if you dont' even try on your own).
make sure you use MMC 7.1 and the DVD 4.1 update.
most of the other info you can find if you search the forums.
ATI Radeon 4870 HDMI audio
By shorto in forum ComputerReplies: 6Last Post: 22nd Mar 2010, 20:56 -
HIS 9600pro ATI 128Mb AGP - driver installation ???
By blinky88 in forum ComputerReplies: 6Last Post: 22nd Sep 2009, 04:52 -
ATI PCI Theatre 550/650 vs AGP AIW 7500, 9600XT
By TaranScorp in forum Capturing and VCRReplies: 3Last Post: 6th Sep 2009, 14:45 -
ATI Radeon Pro 2400 to TV
By bulletb1331 in forum Media Center PC / MediaCentersReplies: 8Last Post: 27th Jun 2008, 14:52 -
What do you think about the Ati Radeon 2600 hd pro?
By davidsama in forum ComputerReplies: 4Last Post: 18th Nov 2007, 15:25
