trying to covert my films i am yousing TMPGEnc but i need the settings as it wont work can you help
when i open the program tmpgenc i go to setting it ill come up with video advanced gop structure quantize matrix audio system i need to know what settings i have to u
se
If you just load in the VCD template settings that come with TMPG you should have no probs. Dont mess with the GOP's or Matrix as that is quite advanced and you don't really need to anyway.
Try reading those "How To" guides over on the left side; they explain it quite well.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
[Help] Problems creating VCDs.
By scott274 in forum Newbie / General discussionsReplies: 77Last Post: 15th Jul 2008, 03:43 -
Multiple VCDs in one DVD
By vid_n000b in forum Authoring (DVD)Replies: 27Last Post: 30th Apr 2008, 03:52 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 11:38 -
I can not play some VCDs on my mechine. Can U help me ?
By wapw in forum Software PlayingReplies: 2Last Post: 21st Aug 2007, 12:46 -
extracting jpegs from vcds
By pk475 in forum Authoring (VCD/SVCD)Replies: 2Last Post: 9th Aug 2007, 11:38
