I have Resident Evil in SVCD format. It is a BIN and CUE file. I burned them to disk and found out that Resident Evil is an SVCD. I cannot play SVCD's on my standalone dvd player. Only VCD's. So now I have an SVCD disk.
So. What I would like to do is take the SVCD disk and convert it to a DIVX or a VCD or both.
I tried looking for a guide for this but din't find one. I also searched the forum and didn't really find anything that did exactly that. I may have missed it. Anyone have any ideas?
Thanks.
use isobuster to extract the mpeg from the bin file or CD. Then convert to whatever format you want.
(other tools will do this also) -
Greetings and Salutations
8)
I use isobuster like bugster suggested (right click on the file and be sure you use the 'Extract M2F2 MPEG-2 frames only' option) and then I use TMPGEnc as per this link
http://www.geocities.com/newestmoviesencode/dvdvcd
It will allow you to play a SVCD encoded movie on a stand alone player capable of playing only VCD. (well... about 95% of the time)
Hope this helps -
Thanks. I will try that.
I also just found this:
http://www.vcdhelp.com/mpeg2tovcd.htm
I don't know how I missed it before!
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 07:25 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Divx to VCD
By d_unbeliever in forum Authoring (VCD/SVCD)Replies: 16Last Post: 30th Apr 2009, 01:19 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 11:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 21:25
