I've finally given up trying to rip THE OTHERS to 1 DVD-R.
I don't know what they've done to it, but nothing seems able to transcode the M2V stream successfully, and yet the original DVD plays OK in everything I tried.
ReMPEG2 gave me hideous results; very blocky. And various versions of tmpgenc messed up the movie length somehow, so after transcoding it the audio was out of sync. I tried a whole bunch of other tools too with no joy.
Does anyone know what they've done to protect this disc?
And is there a way to get round it in the future?
There are things that can happen to cause you these problems.
1) Studio intro is 29.97fps NTSC interleaved.
2) Rating screeen (of FBI warning) is Bottom Frame First 29.97 NTSC interleaved.
3) Main movie is 23.979fps(?) PROGRESSIVE FILM.
Each one requires a different setting to transcode. Best way is to either strip out #1 and/or #2, then transcode #3 separately. Or, you could split this into 3 parts, and transcode each one as it needs to be transcoded.
If you set your transcoder using the settings for #1, then #2 and #3 will be screwed up. If you use #2, then #1 and #3 will be screwed up. And on and on... -
i just finished up the others yesterday, i used cce to transcode and then scenarist to author the disc. everything works perfect. i had some major problems with rempeg as well when the file size was right at 4.37GB, then with cce the file size is about 1.5GB and the picture has undiscernable differences from the original
Help about Copy Protected MPEG-2 files
By bedfordfalls8000 in forum Capturing and VCRReplies: 6Last Post: 9th Apr 2012, 11:00 -
Copy Copy-Protected VHS to DVD
By abazabam in forum MediaReplies: 36Last Post: 12th Feb 2012, 02:25 -
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 07:36 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 00:31 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 11:23
