  1. I export my sequence from Avid DVXpress, as an Avi Uncompressed, 720x576.
    Then I use the Wizard in TMPGencPlus to create an SVCD (Pal). But when TMPGenc downscales my video to 480x576, the picture gets mixed up and lines of the same video appear at the wrong part of the screen.
    What is going wrong and how can I prevent this from happening?
    Greetz
    Apr 2002
    Sydney, Australia
    Are you going to play it in a standalone DVD player? If so make sure it is svcd compatible. I suggest you make an xsvcd and keep the same specs that you exported from avid dont use the TMPG wizard keep it at 720x576 4000cbr. Has always worked for me.
  3. Banned
    Jun 2001
    UK
    Greetz
    Have you set this up ?
    TMPGENc
    Select options > environmental settings
    click the VFAPI plug-in tab
    right click the "DirectShow" and select higher priority, do this several times until its at the top with a value of 4
  4. Will try both your options!
    THX!
  5. maybe your video is interlaced ?
