I dl a movie and want to add in subtitles. I was following the guide from the Edit section on the left but got an error message from Virtual Dub that says,
"VD has detected an improper VBR audio encoding in the source AVI audio file and will rewrite the audio header with standard CBR values during processing for better compatibility. This may introduce up to a 12688 ms skew from the video stream. If this is unacceptable decompress the *entire* audio stream to an uncompressed WAV file and recompress with a constant bitrate encoder. (bitrate 140.9 +/- 15.7 kbs)"
My question is what do I do next? Can you give me an example of a constant bitrate encoder? Should I encode the file to MPEG before I try putting in the subtitles? I'm lost.....
Peace
There is a search button at the top of this page, if you use it and enter suitable text you will see that this problem has been answered many times.
Originally Posted by gmpman
You need to save out the audio, uncompressed
2 methods
1st method
Audio > full processing mode
Audio > compression > Uncompressed
Audio > conversion > 44.1Khz
SAVE WAV
2nd method
Audio > direct stream copy
SAVE WAV
Now you need to covert the output to an uncompressed WAV
Now use the WAV with the original AVI in TMPGEnc -
ok so I save the file uncompressed as WAV. I fully understand how to do that. What do I do about the subtitles though? SOrry about the stupidity but this is the first time I am trying subtitles. I have a deaf friend that I am trying to hook up with a couple of movies.
When you have the SUB's on your video, you will have a choice of using the original AVI and the built in audio, or subsisting the WAV you saved.
I don't add SUB's I take them off
http://forum.vcdhelp.com/userguides/87065.php
http://www.vcdhelp.com/srtsubsvirtual.htm
http://www.vcdhelp.com/subsvirtual.htm
http://www.vcdhelp.com/svcdsubs.htm -
Originally Posted by calvin_10
Well your probably using the second method if the audio is AC3 and "you" cannot do this in Vdub
http://www.vcdhelp.com/tmpgenc.htm#ac3
http://www.vcdhelp.com/faq.htm#divxac3
http://www.doom9.org/software.htm#audio ( HeadAC3he 0.23a )
error message when adding SSA. file to virtual dub
By fredsieg1937 in forum SubtitleReplies: 1Last Post: 24th Sep 2009, 20:53 -
virtual dub "non-zero start position" error
By DaneClark in forum EditingReplies: 1Last Post: 17th Aug 2009, 20:24 -
Error when trying to compress with Virtual Dub
By las7h0p3 in forum Video ConversionReplies: 2Last Post: 7th Oct 2008, 13:39 -
Auto Gordian Knot error issued by Virtual Dub
By loninappleton in forum Video ConversionReplies: 10Last Post: 30th Apr 2008, 11:56 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
