when i framserver with virtualdub to tempgenc ant i burn de vcd.
ik look ad mij stand alone player .
i see in the most movie that the picture is hopping forward what can ik do about this .
i am using xp p4 1500
thanx so far
Results 1 to 12 of 12
thanx for the tip.
Bud the problem ar befor i burn de cd.
ilook ad the movie befor burning and than i see the trouble???
so i dont now what to do about it -
yes it is a original avi only i put de sub in with virtual dub.
the movie name is blade 2 dvd rip
Created by Avi-Info 0.6
[misc]
No of CDs: 2
[video]
Codec: DivXMPEG4 v3
Bitrate: 1284 Kbit/s
Width: 640
Height: 352
Fps: 23.98
[audio]
Codec: AC3-Digital
Bitrate: 438 Kbit/s
Channels: 5 (surround)
Samplerate: 48,000 Hz
i had the same problem's with collateral damge and from hell
i belive from hell had also 5.1 ac sound
i made vcd with mpegenc pal
i am from the netherlands.
i hoop you have a answer.
becaurs i have this problem or for a long time -
Fps: 23.98
enable motion detection to high (slowest speed) ?? -
is this in mpeg enc
in settings?
so this is what i have
video:
video stream setting
sgtream type - mpeg1-video
size - 352*288 pixel
aspect raito - 4:3 625 line pal
frame rat - 25 fps
rate controle mod - constan bitrate cbr
bitrat -1150
vbv buffer size -40
----------------------------------------------------------------- next is gray
profie&lebel -man profile en main level mp@ml
video format - pal
encode mode - non interlace
Yuv format - 4;2.0
dc component procision- 8 bits
Motion search precision -Normal
this are the tings in tmegenc video
is this good??? -
when this are the settings you mean
than i have to make
the
frame rate to 23.98 it is now 25
and
Motion search precision -Normal mus be high slowest speed?
i can also do
highest quility very slow is that oke ?
bud i can shange the setting the are gray how can i changes? -
vlagzalm,
Your original movie is in NTSC ForceFilm format.. that is
you should select a template called NTSCfilm from
tmpgenc. While there are ways to covert it to another
format, the process requires some experience so if
I was you I'd stick to the default NTSCfilm template
UNLESS you cannot play NTSC video cd's on your
DVD player.
Under tmpgenc settings, If the option is grey you have to click on settings, and browse for a template called unlock.mcf (this is sometimes found in the templates/extra folder.
luck! -
when i do that and i burn it als vcd 2.0 than dos it mathar that it is ntsc i think.
if it isvcd than the stand alone player can play it .???
whare and how mus i fill in the tmpg settings.
can you please tell me step bij step?
i hope you will
thanz zo far
my standalone player only play region 2 bud also read vcd 2.0 and svcd 1.0
than i thank can play ntsc burn als vcd 2.0 ???? -
Originally Posted by vlagzalm
both but owners do not have a TV to suit. If you do then it
does not matter if your vcd is NTSC or PAL, although PAL is
better quality.
to use guides under "How To". They are in English but if
you use one of the web translators, they can be viewed
in a number of languages.
Multiple Files & Resolutions In Tempgenc Xpress 4
By TufrThanu in forum Video ConversionReplies: 0Last Post: 9th Aug 2009, 14:21 -
error while burning DVD DL using tempgenc dvd author
By rgpai9972 in forum Authoring (DVD)Replies: 2Last Post: 2nd Jun 2009, 21:15 -
tempgenc authoring works 4 - can I save the edited clips?
By yvonne_1980 in forum Authoring (DVD)Replies: 2Last Post: 24th Mar 2009, 05:59 -
Tempgenc DVD Author small file
By EPLindblom in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2008, 21:39 -
problem with tempgenc plus
By lancerx in forum Newbie / General discussionsReplies: 7Last Post: 6th Dec 2007, 01:35
