I've recently bought the BUZZ capture card and well...it works.
My question is what resolution is a standard HI-8 footage so that I can initially capture in the best I can.
There are settings like KB per frame (default is 44kb per frame going upto 200kb). There are 3 resolutions - 2 of which are 3nnx2xx and one which is about 700xsomething.
You may have guessed I'm not near my home PC right now.
Space is not an issue. As a test I've saved a 5 minute clip on 200kb per frame and the 700x resoultion and it's created a 750mb AVI file. I used nero to burn it as a VCD- took a bit of time, but I think there is still room for improvement, but I don't know how.
I tried to use TMPGENC to burn the VCD, but for some reason the picture is all lines and strong colours when I view it through this software so I left it.
if you want to use TMPG frameserve from virtual dub first
the problem is probably that TMPG doesnt know how to properly read the file
virtual dub will fix that-I have to do the same thing on my AVIs produced by a miro card
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum Capturing and VCRReplies: 7Last Post: 10th Jun 2011, 23:05 -
No audio capture from Hi8 camcorder to PC
By dimtechno in forum Capturing and VCRReplies: 0Last Post: 20th Mar 2009, 15:50 -
Capture Hi8 using what resolution?
By chrishallowell in forum Capturing and VCRReplies: 2Last Post: 3rd Oct 2007, 11:57 -
Hi8 to DV question...
By adameep in forum RestorationReplies: 1Last Post: 8th Jul 2007, 11:35 -
Choppy capture from HI8 in Premiere
By tmann in forum Newbie / General discussionsReplies: 1Last Post: 17th Jun 2007, 14:24
