Hi there ,
I'm trying to create a DVD with spruceup and I'm encountering the following problems :
1. If I add a mpeg movie of 3 Gb Spruceup detects that the file is bigger than 7Gb and cannot continue (by doing some tests I've seen that it always more than doubles the actual value of the original mpeg)
2. If I try to add a mpeg2 in SVCD format to be included in the dvd spruceup simply refuses because it is not in dvd format
Can someone help ?
Alessandro
I would try this:
1. Make sure you have the same filenames for your .ac3 and .m2v files. For example: movie.m2v and movie.ac3
2. You must have the video and audio separated into two different files for SpruceUp to do its thing. If you don't have this done already, I'm sure TMPEG can do the job for you.
cheers,
-k -
You've got issues with your files. Either Spruceup is corrupted (try reloading it) or there is something seriously wrong with your .M2V file. How did you get your .M2V file (and are you sure that you are trying to load the correct file?)?
Problems in authoring DVD
By carlmart in forum Authoring (DVD)Replies: 9Last Post: 1st May 2011, 03:48 -
Audio problems with authoring
By moes in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2009, 15:27 -
Authoring Problems
By DJvoo in forum Newbie / General discussionsReplies: 2Last Post: 10th Apr 2009, 06:58 -
FCP dvd authoring problems
By sksvideo in forum MacReplies: 3Last Post: 18th Mar 2008, 16:57 -
Problems with DVD Authoring
By Velocity_Girl in forum Authoring (DVD)Replies: 6Last Post: 27th Jul 2007, 05:34
