My source is supposedly Progressive PAL, but at every so often there appears to be interlacing...Not the whole screen kind, but the outline of a person who is moving appears to be interlaced! It only last for a few frames, then a few minutes or seconds go by and it comes back...just enough to irritate you.
My question is this: How can you tell if something is interlaced or the source was encoded with visible interlaced-like lines? I've tried pretty much everything except a manual IVTC, but nothing seems to get rid of the lines. Switching field orders and using all of the deinterlacing optins in TMPGEnc's deinterlacer, Auto IVTC, Smart Deinterlace, deinterlace - area based, and deinterlace - PAL frameserved via Vdub, yet the lines are there.
I was reading on www.100fps.com that some video can be transmitted in in both interlaced and progressive streams. Very informative site by the way.
There is also this filter
http://www.uwe-freese.de/vdubfilters.html
It's a time based de-interlacing filter, and being a german site there's a good chance that the filter is optimised for PAL as well.
Let me know how you go -
Thanks for the link D-Knife. www.100fps.com described the interlacing as color interlacing, but that seemed to be the final result of an interlacing technique. I would think that simply deinterlacing again would remove the color interlacing, but its always there. I tried the time based filter and it seemed to make it truely interlaced! I've only been playing with it for a few minutes, but I'll look at it in detail later tonight. Thanks for the link! At least now I know what to call it and what to search for!
randomly deinterlaced frames
By mathmax in forum RestorationReplies: 50Last Post: 6th Jul 2011, 07:30 -
Encode in Interlaced or Deinterlaced w/Pulldown?
By CubDukat in forum Video ConversionReplies: 4Last Post: 19th Jun 2011, 17:29 -
Re-encode/Fix Interlaced MP4 (Film)
By Eva-Unit01 in forum EditingReplies: 48Last Post: 28th Aug 2010, 09:33 -
avchd to deinterlaced avi
By cesarin in forum Video ConversionReplies: 17Last Post: 25th Jul 2010, 12:01 -
I have problem with interlaced or deinterlaced video.
By DVDNow in forum MacReplies: 1Last Post: 11th Jul 2007, 07:18
