HELP ME!
I want to convert my divx to vcd and add subtitles in it!
I m using virtualdub and text sub filter to add subtitles. My subtitles are *.srt and *.ssa!! I can select the files and edit it ,but when i try to preview it there is no subtitles!! Where i go wrong?? I have tried other vcd help guides too,but i could not open the sub files!!
Dear friend, if your subtitles are in ssa format, either you convert them to sub format, or (faster) you use the other subtitle filter : Avery Lee's ssa filter - which actually works very well...
You can find the filter there
http://sauron.mordor.net/dgraft/
Under the 'other' category, together with a whole bunch of other really good filters.
Cheers -
THANKS!
I hahe some *.sub files too, but i cant get them work!!
How can i know what kind of .sub files those are?? and what filter i should use?? -
to mux subs with a avi file i normally do :
1.open movie.avi in virtualdub
2.add the filter (ssa - avery... )
3.then save the avi again, set audio to direct copy / video to full processing and choose de codec and settings
your new movie_sub.avi file will have the subs.
(i can´t frame serve to tmpg, and encode )
make a try
2man
subtitle problem
By cloudsong in forum Newbie / General discussionsReplies: 1Last Post: 27th Jun 2011, 17:18 -
Subtitle Problem
By cyberlion in forum SubtitleReplies: 19Last Post: 24th Jul 2010, 10:44 -
My new subtitle problem
By pensioner in forum Newbie / General discussionsReplies: 1Last Post: 7th May 2010, 04:32 -
Problem expanding subtitle time with Subtitle Workshop
By Kaze105 in forum SubtitleReplies: 1Last Post: 11th Nov 2008, 23:16 -
a problem with subtitle
By matrix man in forum SubtitleReplies: 1Last Post: 15th May 2007, 14:36
