  1. I've used Nero and Ulead DVD PictureShow, but it never has the pause enabled. I would like to be able to pause on a picture now and then. Is there anything I can do? Is this normal or a lacking feature in these programs?
    Thanks.
  2. Hi there. With Nero, once you've dragged your images to the compilation window, set the 'pause' property of these images to 'infinite' (right click on the image or select them all).
    It works for me, my DVD player has PBC.
    Hope this helps.
  3. lihin,
    it depends on your player but if you enable under nero a second or
    two of pause between slides, chances are that your player will have
    the time required to "pause" on demand.
