im trying to cut a mpg using tmpgenc. the file is about 930mb mpg 1. every time i try to cut it , it stops @ 120mb. im trying to split it into 2 so i can fit it in a cd
I just read something like this at the Kwag forums. You may want to try a program called BBmpeg and use it to break up the file.
Available here: http://members.cox.net/beyeler/bbmpeg.html
I haven't used the program myself, but I plan to in the next few hours. From what I understand, TMPEGenc doesn't do a very good job of splitting files. I've never had a problem when selecting specific source ranges, whether its starting at the beginning or middle or whatever, but I guess that's not what you're doing. You already have an encoded MPEG, right? I'm talking about changing the source range while encoding from the actual source, like an AVI or something. I've always dumped encodes when they ended up too big, but that isn't very often.
That's all I got. Someone else may be able to actually give tips regarding TMPEGenc. -
wel i dint encode this, i always encode to the exact to fit it in the cd, i havnt done cutting / split file b4 and now im stuk, dont kno wat to do, wel let me kno wassup , if urz works. thanks for reply to my topic
Try using VCDgear or some similar programme to repair the MPG file before splitting. TMPGEnc seems tempermental this way. Any errors and it just stops---no message---nothing.
You have a bad .mpg and the split wont work, it reaches the bad spot and stops. The best you can do is try to re-encode it again with TMPGEnc and hope it deals with the problem.Originally Posted by buddyr1ce
Depending on how bad the problem is, sometimes you can cut up to the bad spot, the again after it with the source range.
swf to gif help plz
By mraza in forum Video ConversionReplies: 2Last Post: 27th Jul 2009, 03:55 -
Help with Mac The Ripper Plz!!!
By ILoveMovies12345 in forum MacReplies: 2Last Post: 24th Apr 2009, 11:08 -
plz help
By sajjad223 in forum Video Streaming DownloadingReplies: 1Last Post: 4th May 2008, 10:12 -
VirtalDub ERROR - plz help
By UmmAddan in forum DVD RippingReplies: 3Last Post: 30th May 2007, 17:52 -
my PC stats plz help can i edit on this
By Kigi in forum ComputerReplies: 8Last Post: 30th May 2007, 02:30
