i have 256 ram and 900mhz proc running on win2k and when i try to do this function my ram runs out and i get a blue screen stating my physical memory is being dumped.
please suggest a solution... none of the vcd players i have used can play this .dat file so i have to convert it.
If u refresh your page u should see an edit button on the top right
hand side. There is a free program called vcdeasy that, in it's
tools section, can convert a dat to an mpg. See the tools section
on the left hand side
I too suggest that you try VCDEasy. One thing to keep in mind though, I don't think either VCDGear or VCDEasy like making the conversion from a CD-R/VCD. You may need to have enough space on your hard drive to copy the DAT file from the CD-R/VCD. Then activate the conversion on the version that is on the hard drive.
HUN-YA!
Akai Rounin
Burned DVD with my comp = won't play, gf's comp = plays perfectly!
By DVDFuzz in forum Authoring (DVD)Replies: 13Last Post: 16th Sep 2010, 05:39 -
Making a comp. DVD with DVD-Lab Pro..
By Superstar24 in forum Authoring (DVD)Replies: 1Last Post: 26th Jul 2009, 18:24 -
How to corp a dat or mpeg file to mpeg
By onlyrasel in forum VCDEasy GeneralReplies: 1Last Post: 26th Sep 2008, 23:18 -
Making a comp and having some problems need some expert help
By moviedude2525 in forum Authoring (DVD)Replies: 1Last Post: 22nd Oct 2007, 17:03 -
Pinncle Studio 9.4.3 worked just fine, now CRASH CRASH CRASH
By maxtrack in forum Newbie / General discussionsReplies: 18Last Post: 11th Sep 2007, 00:38
