What would cause a VCD to speed up when playing then slow down. When you play it back again in the same spot, it does not always do it at that spot.
Using TMPGnc, Nero, and Daewoo 5000n.
Is this has to do with the player, frame formats (23.96 versus 29 fps) or what? or perhaps the quality of the CDR media?
Difficultly reading media --> possible
Incorrectly multiplexed stream --> possible
FILM vs. NTSC framerate --> possible (assuming you muxed it correctly, then this would be an issue with your player)
Regards.Michael Tam
w: Morsels of Evidence
All video playing half speed?!
By MJ Peg in forum Software PlayingReplies: 8Last Post: 2nd Mar 2010, 12:07 -
DVD software to speed up playing a movie?
By Haopengyou in forum Software PlayingReplies: 6Last Post: 28th Aug 2009, 08:36 -
Why is this? one normal, one yellowish/darker while playing at the same tim
By tigerb in forum Newbie / General discussionsReplies: 1Last Post: 14th Mar 2009, 16:30 -
FFMPEG AVI (XVID) to IPOD Mp4, AUDIO OUTPUT is 2x Normal Speed, HELP!
By jiulonghks in forum ffmpegX general discussionReplies: 1Last Post: 21st Sep 2008, 00:35 -
using a webcam, plus time-lapse software, to make a normal speed video..
By snafubaby in forum Capturing and VCRReplies: 2Last Post: 27th Apr 2008, 02:38
