Hello, I am trying to cut the credits off of an .avi ("What Lies Underneath") so I can fit it onto a CD-R. But when I open it in VirtualDud I get the following error:
" Couldn't locate decompressor for format 'Mpg4' (Microsoft High-Speed MPEG-4)
VirtualDub requires a Video for Windows (VFM) compatible codec to decompress video. DirectShow codecs, such as those used by Windows Media Player, are not suitable. "
It also has similar errors if opened under different apps. Does anyone know where I can download this codec. I tried different sites, but was unable to find exactly what I needed.
Thanks in advance
Mike
Download and instll the Nimo codec Pack. If that doesn't fix it, then it is likeley because it is a MS proprietary codec not supported by Non MS apps.
P.S. If you have win ME or XP you should be able to do this in MS MovieMaker
Fixing an MPG4 file
By Linz1607 in forum Video ConversionReplies: 1Last Post: 30th Nov 2010, 11:45 -
MPG4 File Repair
By RickGaspar in forum Newbie / General discussionsReplies: 2Last Post: 6th Jun 2010, 12:14 -
Help with brief video freezes in mpg4 avi
By hibbs in forum Newbie / General discussionsReplies: 5Last Post: 28th Apr 2010, 19:04 -
FLV format conversion to MPG4
By Simon5005 in forum Newbie / General discussionsReplies: 1Last Post: 27th Jul 2008, 11:09 -
MPG2 or MPG4???
By JennyBear in forum Newbie / General discussionsReplies: 7Last Post: 1st Aug 2007, 18:33
