    Aug 2001
    Adelaide
    Please Help !
    I am currently having problems with audio underflows with one particular movie file. The resultant vcd is picture perfect but the sound occasionally breaks up. The notes suggest that I should increase the mux rate. Does any one know what this does, and how much should I increase it to. I tried increasing it to 10 but the program hung right at the end of the process.
    Also, if there is an mpeg audio file is this a vcd compliant format to copy direct or does it need to be decoded ?
  2. What encoder are you using with flask?
    Aug 2001
    Adelaide
    I'm using DVDDecrypter, which had worked great so far until now. It had problems with a couple of files
