I installed VCDEasy and it said NO CD WRITER FOUND OR ASPI DRIVER PROBLEMS. I followed the guide from VCDEasy on how to install and check ASPI drivers and downloaded the Force ASPI 1.7 program. According to those directions I am to DUMPASPI.BAT in order to backup my current configuration. But I get a message that ASPIENUM.VDX files does not exist and backup is not possible. Then I am to INSTASPI.BAT to install a new layer. Then I get a registry error that says "Cannot import Win9x\Win9x.reg:Error opening the file. There may be a disk or file system error." So I reboot my computer like told and then I run the aspichk.exe program to check if everything is running ok. That reads ASPI is not properly installed. One or more components have been replaced with older versions of the software. And I still cant get VCDEasy to recognize my CD writer drive. Do you have any suggestions? Should I use a different VCD writer program? I'm open to anything.
Results 1 to 1 of 1
DVD Writer problem
By tapal in forum ComputerReplies: 3Last Post: 23rd May 2008, 05:36 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 09:17 -
DVD writer problem???
By championjosh in forum DVD & Blu-ray WritersReplies: 6Last Post: 26th Feb 2008, 15:04 -
problem with dvd writer
By daniel1800 in forum DVD & Blu-ray WritersReplies: 9Last Post: 7th Jul 2007, 18:47 -
dvd writer problem
By ellabbs in forum Authoring (DVD)Replies: 1Last Post: 6th May 2007, 04:47
