I like to reduce a given MPEG-file in VCD 352-288 format (it is now 45MB) substantly, so I can attach it to an e.mail. My provider accepts 4 MB.
Decreasing quality is no big problem.
Is there a tool that can do this? TMPGenc not seems to support such facility.
twoages2,
You can reduce it using Divix (see left hand side "Convert" link)
but keep in mind that it will only be playable on a computer
and that computer has to have the appropriate codec loaded.
Using Tmpgenc u have to lower the bitrate and the resolution
under "settings". Try 120x90 at 143kbs. It will be postage stamp
sized tho.
Reduce MPEG-2 filesize without losing too much quality?
By yic17 in forum Video ConversionReplies: 10Last Post: 26th Oct 2012, 08:02 -
How to reduce filesize and to not lose too much quality?
By xxxThiefxxx in forum Blu-ray RippingReplies: 5Last Post: 9th Aug 2011, 08:48 -
Need mpeg-1 to VCD tool that splits
By anadiner in forum Authoring (VCD/SVCD)Replies: 14Last Post: 4th Dec 2009, 04:24 -
Reduce VOB filesize
By jacktorrance in forum Video ConversionReplies: 8Last Post: 14th Jan 2009, 11:34 -
reduce bitrate of mpeg file
By bradlewa2 in forum Newbie / General discussionsReplies: 10Last Post: 24th Apr 2008, 09:32
