i'm using the latest version of TMPGenc to encode some DV camcorder movie clips. i have used all different types of settings up to 8000kbps rate cbr, or 7000kbps rate vbr with the motion search precision set to highest quality (slowest), noise reduction on etc, but a still get a 'shimmering' effect (is it called moire?)..i'm burning using Ulead DVD Workshop on a Pioneer A04. i was hoping that by encoding at the highest possible quality, i would get DVD's at approx the same quality as my DV tapes. are there any other encoding settings or programs i should be using?...is this a media problem?
Results 1 to 11 of 11
by default the field chosen is 'bottom first', but i have already tried it with 'top first' - no change in quality
in still mode, or when there is very little motion, the quality is ok. it's when there is movement that the 'shimmering' occurs, so not sure how to capture a screen shot to show the problem.
i had exacly the same problem,do you know why??
because tmpeg sucks,thats why.
use cinema craft or vegas video 3.0 and you see the diference!!! -
I haven't tried Vegas yet.
CCE is VERY VERY good - but hard to get to get a suitable output.
Stick with it and it will give very good results
need help with AVStoDVD settings to make best quality video for DVD
By granturissimus in forum Newbie / General discussionsReplies: 4Last Post: 29th Jan 2011, 16:00 -
HELP! RipBot Settings for Highest quality HD-DVD to Blu-Ray Project
By clarkkent57 in forum Blu-ray RippingReplies: 6Last Post: 9th Sep 2010, 12:58 -
DVD to DivX - settings for better quality
By CodeMaster2008 in forum DVD RippingReplies: 11Last Post: 14th Jul 2009, 03:20 -
Megui quality settings, need some clarification
By llmercll in forum Video ConversionReplies: 6Last Post: 2nd Feb 2009, 01:10 -
Output quality and settings of DVDShrink
By src2206 in forum DVD RippingReplies: 21Last Post: 23rd Jan 2008, 06:38
