I've ripped Towering Inferno using Smart Ripper and got a 2.46gb M2v file and 1.71gb WAV file.
I am trying to use SpruceUp to author the DVD but am getting nowhere. I can't figure out how to deal with the WAV file.
Can anyone out there help a confused newbie??
When you did the ripping, did you select both audio and video to "demux to an extra file" in the Stream Processing tab ? This should have given you "AC3" and "m2v" files, then rename both files the same (probably the films title) and when you open up the m2v file in SpruceUp it will automatically find the ac3 file.
A good guide to follow for this is here.
www.dvd2dvdr.com
Cheers
Chris. -
I've just noticed your PCs OS, you might run into trouble when the movie file is larger than 4Gbs
Cheers
Chris.
