Any way to join two AC3 files together? I have tried virtualdub but when I try to convert the ac3 with Headac3e, i get errors in the stream... Perhaps the is a AC3 fixer program out there somewhere...
I know i could convert to WAV and then join, but that takes ages and i just havent got the disk space....
How about the Dos command...
Open a Dos box and type
copy /b a.ac3+b.ac3+c.ac3 abc.ac3
where a, b c etc are the names of your ac3 files, abc.ac3 the name of the resulting file.
/b identifies the files as binary.
Should work if all the files are at the same sample rates.
joining AC3 5.1 audio
By avengerevenge in forum Newbie / General discussionsReplies: 3Last Post: 17th Dec 2010, 11:02 -
Editing & joining AC3 tracks
By carlmart in forum EditingReplies: 1Last Post: 18th Apr 2010, 12:06 -
Joining AC3 files on a AVI or MKV?
By CactusMan in forum Newbie / General discussionsReplies: 2Last Post: 13th Jan 2010, 19:44 -
Joining MPEG2 files with different AC3 audio delay on each file
By Killer3737 in forum EditingReplies: 6Last Post: 27th Oct 2008, 23:32 -
Joining M2V & AC3 files for DVD burning, Subtitle creation sub position
By blue2 in forum Authoring (DVD)Replies: 15Last Post: 29th May 2007, 08:56
