I've seen some really sharp looking VCD's of peoples own video. When I try to convert mine, I end up with lots of ugly pixels (little squares) all over the playback on my TV.
Is there some way to clear this problem up?
Scenario:
Standard VHS tape (football archive footage)
AMD Athlon 1333 with 256Meg ram & 80GB of HD space
ATI all in wonder Raedon (with TV) card
I'm just starting, so I'm not tied to a specific encoding program. I have the 30 day trial of Ulead Video Studio and just downloded TempEncodes trial version.
This is for realistic playback on a TV set with a DVD player capable of VCD and SVCD. I know it's video and it has noise. I'm not expecting a miracle, jsut the best possible steps from capture to final burn that will give me a smooth production.
When you set up to capture the video from the tapes, what are your resolution/bitrate settings?
Are you capturing at a higher resolution and bitrate than your VCD/SVCD end product, then converting down to the resolution and bitrate of the VCD/SVCD, or are you attempting to save time and just capturing straight to VCD/SVCD specs?As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
I've tried both methods. the "VCD" setting, and then a customized AVI setting, 720x480 I believe. Then I converted it down, but still got lots of little squares.
I am getting the same results. I am going from DV to avi, then creating vcd, but get a ton of squares. Please explain what settings are the most important.
First, if you are capturing from VHS your res is limited by the source (320x240 or 352x240) I think. What I do is capture using 352X240 2250 kbs mpeg1 with ATI AIW 128. Then I run it through TMPEnc mpeg merge\cut tools (seems to make it work better in my DVD). The resulting video has no blocks but, is what I call grainy. It is quick and not bad quality.
For DV I use fire wire and Studio 7 to capture to full res AVI. Then encode as 352x480 mpeg2 3600kbs 2 pass VBR using TMPEnc. This takes lots of time (12+ hrs) but qulity is super. When in a hurry I do similar to above (but mpeg2 and higher bitrate)with ATI AIW even with DV.
In either case lots of bits equal lots of CDs
Mpcstar pixelation problems picture becomes clumped squares
By kakashi9401 in forum Software PlayingReplies: 0Last Post: 15th Jul 2010, 14:52 -
why do cds or dvds stick or show squares or slow down when playing?
By wan2no in forum Newbie / General discussionsReplies: 12Last Post: 4th Apr 2008, 22:09 -
A font with only squares, how to create?
By sybariten in forum ComputerReplies: 3Last Post: 21st Feb 2008, 16:38 -
Squares Appear When Playing Online Games - Resolved
By HacktheHacker in forum Software PlayingReplies: 6Last Post: 20th Jan 2008, 17:07 -
3d Games Cause Large Squares on Screen - SOLVED!
By HacktheHacker in forum ComputerReplies: 11Last Post: 29th Jun 2007, 20:59
