When I try to burn "Blade 2 CD1.mpg" onto a blank CD using VCDEasy, but an error comes up all the time... heres the code:
[Internal Xml Generation]
Internally computed XML generated successfully as "C:\WINDOWS\Profiles\Paul\Desktop\videocd.xml"
[VCDxBuild.exe]
GNU VCDImager 0.7.12
initializing libvcd 0.7.12 [cygwin/i686]
this is the UNSTABLE development branch!
use only if you know what you are doing
see http://www.hvrlab.org/~hvr/vcdimager/ for more information
changed volume number to 1
changed volume count to 1
changed restriction number to 0
changing 'next volume use sequence 2' to 0
changing 'next volume use lid 2' to 0
changed volume label to `BLADE2_CD1'
changed publisher id to `VCDEASY_V111'
changed application id to `CDI/CDI_VCD.APP;1'
changing 'relaxed aps' to 0
adding pbc (Selection-000/2)
adding pbc (Selection-end/3)
sequence count 1
adding sequence #0, C:\Program Files\KaZaA\My Shared Folder\Blade 2 CD1.mpg
strange (possibly non-compliant) user_data seen... (not a problem, usually a sign of TMPGEnc)
pts start offset 0.346711 (max pts = 3317.706711)
playing time 3317.360000
scanning mpeg sequence item #0 for scanpoints...
already scanned... not rescanning
pbc: psd size 32 (extended psd 56)
iso9660: highest alloced sector is 257 (using 300 as isosize)
writing track 1 (ISO9660)...
writing track 2, MPEG1, PAL SIF (352x288/25fps), audio[0]: l2/44.1kHz/224kbps/stereo ...
MPEG packet statistics: 207701 video, 40760 audio, 0 zero, 0 ogt, 362 unknown
writting post-gap ('leadout pregap')...
finished ok, image created with 249498 sectors [55:26.48]
[CDRDAO Disk Info]
Cdrdao version 1.1.5
1,1,0: IDE-CD R/RW 4x4x24 Rev: 1.08
ERROR: No driver found for 'IDE-CD R/RW 4x4x24' (Try to use "Force Driver" in the "CDRDAO settings" page, with 'generic-mmc' for example)
ERROR: Cannot setup device 1,1,0.
I have tried wot it suggested at the bottom to use Force Driver but it still doesn't work, anyone got any suggestions please?
Also check the ASPI driver.
http://www.svcdeasy.org/modules.php?name=_Guides&id=Cdrdao#ASPI
Error: The source image format is not acceptable (error code -2)
By Russo in forum DVD RippingReplies: 3Last Post: 5th Jul 2011, 10:50 -
Registration Code Error
By ghillman100 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 16th Apr 2011, 10:07 -
Error code on my Pioneer DV-868Avi
By Melmac in forum DVD & Blu-ray PlayersReplies: 1Last Post: 24th Jul 2009, 08:15 -
FAVC error code
By drz400 in forum Authoring (DVD)Replies: 10Last Post: 10th Oct 2008, 16:18 -
Error: Sense key=Medium Error. Sense Code=0x73, 0x03.
By Idlewild in forum MacReplies: 14Last Post: 10th Mar 2008, 11:36
