i converted a divx 2 cd(ntsc film,ac3 audio)to dvd and the audio and picture are jumping
i used the vcdhelp guides,TMpgEnc ,virtualdub ,headac3he etc
i think it may be because the framerate is 23.976 and dvd compliance is 25for pal or 29 for ntsc ...erm i dont really know any help would be much appreciated
I have used the following technique when doing final Authoring with DVDit (Some other authoring progs do not accept the resulting mpegs)
(This is from memory so I hope its right)
Extract the audio with virtualdub, convert to 48Khz wav file whatever way you wish.
In TmpGenc, select your divx as video, select the video only radio button. Load the DVD (NTSC) template. Load unlock.mcf and click settings.
On the video tab, select frame rate as 23.97fps
On the advanced tab, ensure 3:2 pulldown is NOT ticked.
On the GOP structure tab, ensure "number of pictures in P frame" is 4
Encode.
Now take your .m2v file and run it throught pulldown.exe (might be in the tools section, if not try google)
this will give you another .m2v file with the relevant 3:2 pulldown flags set for 29.97fps playback.
Now use this .m2v file and the wav file for audio in DVDiT or MyDvd and author as normal.
This works for me.
I also use Dazzle DVD complete to author. For this, In Tmpgenc, load DVD NTSC template, load unlock.mcf. Change nothing except on advanced tab where 3:2 pulldown MUST be checked (for NTSC film source). Encode and author.
If you have a different authoring proggy and neither of these work for you ask again, I am sure some one can help.
Let me know how you get on.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 14:00 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 13:00 -
Would synch mostly occur on DVD to DivX, or XviD to DivX?
By rocky12 in forum Newbie / General discussionsReplies: 3Last Post: 29th Oct 2008, 02:01 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 11:24
