I have a problem when I encode divx files to XSVCD at <1800 bitrate using TMPGEnc 2.56 because it would pause at some moments every 10-30 seconds. Anything >1800 works great. This only shows up when I play it on the computer, I tested the same process of encoding and playing on another computer, same thing. But, when I stick it in my DVD player, it's fine, no pauses. When I re-encode, the pauses would be in another place or sometime in the same place. I tried it with many other DivX files, same results.
Another thing is some of my DivX files have VBR audio, which caused it to lag after a few minutes of watching or pause and speed up after I encode it to VCD/SVCD, I did seperate the audio from video, still same thing. I used VirtualDub and NanDub, both didn't help.
I solved the 2nd problem, all I had to do was not set Compression > Sampling Rate in VirtualDub to "44100Hz". I had to leave it on "No Change" and then encode it in TMPGEnc as 44100Hz.
Can anyone solve the 1st problem, I tried using v2.55, but the problem was worst. Maybe it's a bug in TMPGEnc and v2.56 fixed more of it. -
Bah, no one knows the answer. I give up after 2+ weeks of messing around, if it plays perfectly on my DVD player, then that's all I can do then. If my friend's DVD can't play my XSVCD, and tries to play it on the computer and it pauses, oh well then,
Divx Converter Problems
By Maritimer in forum Video ConversionReplies: 11Last Post: 18th Dec 2009, 13:00 -
Divx Plus HD problems
By ColinMorrison in forum Video ConversionReplies: 9Last Post: 2nd Nov 2009, 10:04 -
DivX Encoding Problems
By ftshark in forum DVD RippingReplies: 3Last Post: 7th Mar 2008, 11:30 -
Divx 2 DVD Problems
By KilinKind in forum Newbie / General discussionsReplies: 8Last Post: 8th Aug 2007, 08:03 -
DIVx to DVD problems
By ulm4lyf in forum Newbie / General discussionsReplies: 8Last Post: 17th Jul 2007, 00:26
