I have used vfapi to convert dvd project files to avi for editing but when I try to open them I get an error cannot determine file type?
Any help?
You want to convert dvd project files, I guess .d2v files.
Then you convert the project to "avi" with VFAPI. At that point you try to edit the avi? No, VFAPI converted AVIs are not real AVIs, it's just another project or something like this. You can open this *vfapi.avi in a MPEG encoder or VirtualDub to encode to a real .avi or .mpg. But keep the .vob, .d2v, *vfapi.avi all in the same directory, don't delete any file of these.
I hope I have understood your question. -
I'm having this same problem. I frameserve my captured file from VDub to Tmpeg and then after IVTC it (manually) I save the project. My first aim is making SVCDs, however, I would also like to be able to use nandub to make a divx version, so I use VFAPIConv to load the project file and convert it to the dummy avi file.
The problem comes when I try to load that dummy file into nandub. I get the message "cannot determine file type".
This is my first time using VFAPIConv so I must be doing something wrong. Can anyone help?
AVS to psudo-AVI via VFAPI (1.05), in a BATCH FILE?
By RogerTango in forum Video ConversionReplies: 1Last Post: 6th May 2012, 01:49 -
Editing Programs.. Hopefully freeware
By sgt_hanky in forum EditingReplies: 2Last Post: 9th Dec 2009, 07:09 -
Do any of these editing programs work well?
By 392 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 11th Jan 2009, 21:33 -
cannot get video into editing programs
By hailmary in forum Newbie / General discussionsReplies: 4Last Post: 9th May 2008, 01:43 -
Captured audio from .mpg file can't be seen/read by many programs!
By omnikai in forum AudioReplies: 4Last Post: 16th Sep 2007, 15:09
