New user with Dazzle Mojave Device, plus VideoWave 4.0. When I try to use other capture programs I receive the message "Device Already in Use"
How do I free up the device to use elsewhere. Using Win XP. Thanks.
Are you closing the program that you are not using? Capture devices cannot multi-task, as you probably know.
Hello. -
Yes the program is closed. That's what I don't understand why it's still in use. Where is it in use!!!
did u try alt + ctrl + delete? if you see it running, just end it.
I see this error all the time after a capture program crashes or exits not-cleanly
with my Asus V7700.
Probably means your capture program does not properly release the capture device. -
I'm new at video capturing. One thing I neglected to mention, I'm using Dell MovieStudio 11. Video Wave 4, Dazzle hardware is all bundled. I've discovered quite a number of users are having the same problem. No other capture,edit programs can be used when you use this product. If you try to capture from 8mm tapes I & many others receive a copyguard error message. No one seems to be able to solve this problem.
The device USB 2861 device could not be opened
By Fabis94 in forum EditingReplies: 5Last Post: 20th Nov 2010, 13:40 -
can't recognize device...
By stymuli in forum Newbie / General discussionsReplies: 1Last Post: 26th Apr 2010, 14:14 -
device error
By alintatoc in forum ComputerReplies: 7Last Post: 8th Jan 2010, 10:53 -
HD Pvr 1212 - device is not connected - can't use device in arcsoft softwar
By yoda313 in forum Capturing and VCRReplies: 9Last Post: 16th Aug 2009, 17:22 -
Trying to locate a device in Device Manager
By alegator in forum ComputerReplies: 2Last Post: 13th May 2009, 10:53
