Don't realy know if this is writer the right place...
Any way to mix two sound together?
I rip music videoes and need to mix some music and and some video together, so that they will play at the same time, I mean put the two sound on top of each other....
hope some one can help
PS: if some one have a turtorial for soundforge or/and Premier I would be glad if I could get em.
You are right, it is called "mixing". If you have Gold Wave, it gives you step-by-step instruction (about a four step process) in its Help section. Sound Forge should have the same function, so you may want to check your version of Sound Forge.
Hello.
Sound Forge puzzler...
By mjl1297 in forum Newbie / General discussionsReplies: 3Last Post: 27th Aug 2011, 08:19 -
Using equalizers in Sound Forge 10
By Xdecade in forum AudioReplies: 0Last Post: 6th Jun 2010, 13:12 -
Sound Forge Help
By ZOMBE in forum AudioReplies: 2Last Post: 28th Jun 2009, 07:46 -
Removing Scratchiness with Sound Forge 8?
By solarblast in forum AudioReplies: 12Last Post: 17th Nov 2008, 10:30 -
Goldwave or Sony.Sound.Forge
By lucid_dreams in forum Newbie / General discussionsReplies: 4Last Post: 1st Mar 2008, 00:33
