  1. I have an AVI movie that I downloaded that was encode with:
    Frauenhofer IIS MPEG Layer-3 Codec
    Im trying to conver it to MPG but the problem is that when the conversion is finish, the mpg goes fast and change colors along the way, the picture goes red then green so on.
    Can anyone help me? I tried to conver it to an uncompressed AVI, but it does the same.
  2. Banned
    Jun 2001
    UK
    The codec you talk about is an audio codec (MP3)
    However this should not matter as long as you have the codec installed (Nimo codec pack) has them all.
    If your using TMPGEnc to encode to mpeg1 try this
    TMPGEnc
    Select options > environmental settings
    click the VFAPI plug-in tab
    right click the "DirectDraw" and select higher priority, do this several times until its at the top with a value of 4
    One last thing, if you have the SMR (Angel portion) codec installed, un-install it, its rubbish and can also cause problems like this.
