I am trying to use DVD2AVI to get the AVI file for SVCD encoding in TMPGEnc. It loads the movie VOB file, but makes the avi file in about 10 minutes...
I just used it to get the avi file for a 90 minute movie and it took 40 minutes... The movie I am trying to do now is BEHIND ENEMY LINES....
Is there something out there to get around the DTS???
Thanks for your time...
Sorry if this has been covered before.I did a search and came up with something but I do not understand the post?
Spankey
I do not recommend to save the avi, just save the project and frameserve to your favorite encoder.
SVCD does not support DTS audio.
DVD2AVI 1.77.x support DTS demultiplex. If you want to create a DVD and if you have an authoring tool, that support DTS audio, you can use that option.
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 16:25 -
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 21:24 -
Convert DTS-MA to DTS with XMedia Recode?
By smackyourfupa in forum Blu-ray RippingReplies: 3Last Post: 14th Apr 2011, 08:23 -
how to convert dvd with dts audio to a dvd playable on a dvd player
By flannob in forum Newbie / General discussionsReplies: 5Last Post: 19th Sep 2010, 06:46 -
How to convert AVI with DTS audio to DVD
By Jean in forum Video ConversionReplies: 6Last Post: 24th Aug 2007, 01:25
