Hi i am very new to burning DVD-R and have a pioneer a04 or 1.04 depending on where u live lol. Anyway i have backed up a couple of dvd's on final destination and the other black hawk down. Final dest. was simple cause it was under the big 4.5gb and ran a dream even when skipping chapters. Black hawk down was another story over 6gb and had to be shrunk with rempeg. I have watched the dvd-r and the last few chapters skip and go very blocky could this be the authoring tool i used spruce up 1.1 for both is there better alternatives?? Or could it be the dvd-r discs i'm using techno dvdr media.
My system is an Athlon 2000XP
512mb pc2100ddr ram
windows XP Pro.
Thanks guy's.
i had the exact same problem.from what i gathered it was the discs.if i used slightly better quality dvd'rs it never happened again.
i now use data-safe generation3.dvdr's from.
www.blankdiscshop.co.uk/acatalog/
hope this helps
DVD Authoring with Windows MM 2.6 OR AVS Authoring
By jagman in forum Authoring (DVD)Replies: 3Last Post: 8th Oct 2011, 04:41 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 19:16 -
Great Article On Current BD Authoring Solutions & Future Mac Authoring
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Dec 2008, 17:04 -
converting multiple avi's to dvd's What proggie to use?
By Magnuson in forum Video ConversionReplies: 4Last Post: 18th Aug 2007, 03:42 -
TMPGEncDVD authoring 3 with divx authoring
By buttzilla in forum Authoring (DVD)Replies: 0Last Post: 11th May 2007, 21:51
