Hi,
if I captured analogue video via(passthru) a dv camcorder and firewire is the resolution I can capture in always a set size. I want to capture using a lossy codec to enable me to get a few hours recording in one session and I havnt got the harddrive space for dv resolution. TIA.
well... if you are TRANSFERING from your dv cam you have to traqnsfert it as is but you can buy a capture card and choose whatever codec you might like and the size you want
hope that helps
what resolution will a DVD recorder set-top capture.
By xbill in forum DVD & Blu-ray RecordersReplies: 6Last Post: 11th Jan 2012, 16:40 -
videocast osprey capture resolution
By jaybird in forum Capturing and VCRReplies: 0Last Post: 27th Apr 2009, 23:29 -
tv tuner/analog capture resolution problem
By cooldude859 in forum Capturing and VCRReplies: 4Last Post: 13th Dec 2007, 02:16 -
Capture Hi8 using what resolution?
By chrishallowell in forum Capturing and VCRReplies: 2Last Post: 3rd Oct 2007, 12:57 -
capture resolution
By stompinne in forum Newbie / General discussionsReplies: 1Last Post: 24th Jul 2007, 15:45
