have posted this before, but no replies, please help
have captured a music video from vhs to my hard drive but, the audio track is not very good quality (this is how it was on vhs) so i want to replace the audio track from audio cd. ( they mimed on the video so the cd Track should match up)
Whats the best way to do this? which software is the easiest for a newbie to use?
Any info would be greatfully appreciated.
Thanks.
You don't say so I will asuume you have the video in avi format. I would do this:
You will need some software that will 'rip' the required track from your CD into a wav file. 'fraid I can't tell you what to use but go to a site like download.com and search, there are many proggys for this.
Open avi file in virtualdub
Select Video->direct stream copy
Select Audio->wav Audio, select your CD track wav file
Select file->Save avi
This will save a copy of your avi with the audio replaced by the track from the CD.
Getting the two in sync, well thats another matter altogether!!! -
Hi, thanks for the reply,
I have the video in Avi format and have the track ripped from cd ready to replace the original audio track, i have virtual dub too, but as you pointed out, it`s difficult to getr the two in sync. Anyone know how?? -
The only way I can think of is to do it manually. This is OK (ish) if the two run at the same speed but will be a nightmare otherwise. In the 1st case, virtualdub will allow you to specify a start offset for the audio. Select Audio->Interleaving and set the Audio skew value to whatever is needed. Then save your avi as I previously described. If the audio and video run at different rates then you are on your own as far as my help is concerned, sorry
bugster, thanks for the help.
I Will give it a go, but im sure there must be an easier way.
Anyone with any more ideas, please post.
Thanks -
what I can suggest is that you load the avi into virtual dub
click on the END button to go directly to the end of the video
write down the total time and then get the time of the audio file as well
I think there is a guide for synching
and I just checked to make sure and there is
click on EDIT on right side and go to complete bottom of the guides page
well not complete bottom but here is the heading
"How to repair downloaded video clips or fix audio sync problems"
that should help you some.
enjoy!
*editted to remove typos
Replace .MKV Audio with Different Track
By Justron in forum Video ConversionReplies: 2Last Post: 1st Feb 2012, 18:03 -
How do I replace audio track on Mp4?
By unwired in forum EditingReplies: 3Last Post: 24th Jul 2011, 15:53 -
Best way to replace an Audio Track on x264 Video Movies...
By erosoft in forum Blu-ray RippingReplies: 2Last Post: 4th Dec 2008, 10:25 -
replace audio track in retail DVD
By foolosophy in forum AudioReplies: 7Last Post: 2nd Aug 2008, 19:04 -
how to replace an audio track to a music video and getting it to synch
By alarmsman in forum AudioReplies: 1Last Post: 20th Jun 2007, 15:06
