Hiya,
When VCDEasy loads I recieve the error: 'No CD Writer/reader found or ASPI drivers problem.' I updated my ASPI drivers to 4.7 I believe it was. I dont know how to fix that problem.
Aspects (In Case Hardware/Software Related).
XP Home
2.0 GHz
256 RAM
nVIDIA GeoForce 2 MX 400
80 GB HD
Thanks for your time!
Try reloading the ASPI, or going to an older version. I had this problem too once. Also, make sure you don't have a disc in the ROM drives. I had a bad burn on a disc and when I tried to use VCDEasy with the disc in I got a similar error.
I had the same problem also and I tried reloading ASPI a couple of times so I ended up getting Nero to write the .cue and .bin but once I installed Nero VCDEasy started to work. I have no idea why it did that but now it works and i'm happy.
Well I uninstalled Nero 5.5.8.2, uninstalled VCDEasy, reinstalled VDEasy, and Nero 5.5.8.2, and I still receive the VCDEasy error. Ill try to go to an older version of ASPI I suppose, but still ANY IDEAS?
REMEMBER: There is a 255 character limit! There is a 255 character limit! There is a 255 character limit! There is a 255 character limit! There is a 255 character limit! -
If someone could maybe provide some ASPI download links? I have 4.7 but it obviously isnt working, and I cant find a place for 4.6. Please help.
You'll be needing to look for "ForceAspi", d/load this and follow the instructions.
Chris. -
Thank you very much mrbingley! I noticed it installed ASPI 4.6 and I was actually tryin to get it but couldnt find it...
Thanks a lot man!
You can get it from http://www.doom9.net
Good luck. It should solve your ASPI layer problems!
Regards.Michael Tam
w: Morsels of Evidence
Administrator Privilege to Run VCDEasy
By asifmcp in forum VCDEasy GeneralReplies: 2Last Post: 8th Jan 2011, 04:48 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 20:00 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 08:17 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 15:13
