on the sys req it say 700mhz
i want to know it i can use it on my k6-2 350 or if needed my k6-2 500
i know some things can work fine on a computer that has less then the sys req
Results 1 to 9 of 9
104 has got buffer underun protection, so it should work on both...
BUT with cpu prices so low why are you using such slow processors? In the UK a Duron 800 cpu is under £30! Plus, if you're using a 104 to author dvd's, then you'll need a huge hard drive, at least about 3 times your project (4.33 gig * 3 = about 13 gig) spare!
Think about your system spec's before you buy a 104!
And remember it's only a 2x drive, so will take a long, long time if your system can't keep up! -
buy a 1500mhz p4 for $100us
buy some more ram
buy another hard drive
cause u know how much space u reallly need
enough is never enough -
can you even play a dvd on that?
(i'd actually like to know)
i don't think it'll work on your comp it just doesn't have the power to pull it off maybe the 500 mhz one... -
well i have over 180gig in hdd space on the 350mhz
yes a dvd will play on it dvdrom drives came out when the p1 233 was out i belive
i am going to be buying a amd 2100+mp with over 800gig hdd and like 2 gig in ram soon -
i am not goign to be doing much prossesing i will be doing thing like backing up xbox/ps2 and buring data mainly not doing much video prossesing work
That's not the point I was making.....
The 104 will work, but if you're system can't keep up, then it will take a long, long time to burn your ps backups, as the system will be playing catch up! Burn-proof will stop the backups from being coasters, but is it worth it?
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 23:13 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 08:20 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
How much do you work? (work = doing something you are getting paid for)
By Baldrick in forum PollsReplies: 20Last Post: 26th Nov 2007, 16:35 -
more ram?
By Heywould3 in forum ComputerReplies: 7Last Post: 24th Jul 2007, 12:32
