first off i have made 40 vcds using these guides thanks to vcdhelp.com
but now i have my first real problem that i could not find a fix.
so can some one please help .
I have tryed using dvd2avi all tracks and vob2audio and nether will see
or find the sound in the vob files from shallow hal,jimmy neutron and Rollerball . strange huh . thought so. well its not like when i had a prob ripping behind enemy lines and vob2audio fixed that one for me.
here is the streams from them.
Streams 1.4, by Tsunami, crypter@gmx.de
0x20 is Subtitle English
0x21 is Subtitle Francais
0x22 is Subtitle Espanol, Spanisch
0x23 is Subtitle Francais
0x24 is Subtitle Espanol, Spanisch
0x21 is Subtitle Espanol, Spanisch
0x22 is Subtitle Francais
so as you can see they do seem to have sound and iam major lost now i tryed removing any new software and so on so on.
please help
Anx
	well iam still stumped can some one please help .
 ive tryed dvd2avi and it willnot make any audio wav or ac3 file and vob2audio just loads empty dotted box .
 thanks Anx
	 Well i figered out the problem if anyone whants to know? Well i figered out the problem if anyone whants to know?
 Its not with vob2audio or avi2dvd fault it was smartripers
 when you put a dvd in the computer it auto changes what sound files
 you whant and causes all other software not find it because its not there
 so you have to hit all streams to get vcd sound files on your hard drive
 and bingo thats it. hope this helps any one who has ran in to this little problem.
  Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 20th Aug 2010, 00:11
  DVD2AVI/DGIndex Aspect Ratio Problem (Long/Stretched Faces, etc)By munkeyman in forum DVD RippingReplies: 7Last Post: 19th Feb 2010, 10:47
  How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 09:38
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
